Frequent Contributor II
VIA & Controller Model
How many VIA users are supported for : 620 , 650  , 3200 & 3400 Sereis
i cann't find this info @ datasheet ?
Aruba
Re: VIA & Controller Model
Good morning Telnet.
IPSEC session count for each is listed on the controller matrix located @
http://www.arubanetworks.com/pdf/products/matrix-mobility-controller.pdf
JF
Aruba
Also consider the number of VIA users using SSL failback (if enabled):
AMFX | ACCX | ACDX | ACMX
Aruba
That's a good point!  Thanks for adding.
I haven't yet seen a site use SSL myself, but it is indeed there.
JF
