Valued Contributor I
VIA client initial connection and authentication phases etc...
Hello all.
I was asked recently if I knew exactly how the VIA client initiates, encrypts and authenticates its connections. I realised I don't!
Does anybody know if a doc exists describing it? What I could do with is something showing the ipsec phasing and credentials exchange etc etc including when it's encrypted and when not, and when usernames etc get passed.
Any pointers gratefully received!
Thanks.
Kudos appreciated, but I'm not hunting! (ACMX 104)
Re: VIA client initial connection and authentication phases etc...
I am attaching a document that has the detials relating to VIA application.
Let me know if this was useful
Venky.
