Hello
Where can i find VIA maximum concurrent users connected to a controller
Specifically to a 650
Cheers
Carlos
Is this calculate by the maximum number of ipsec tunnels to the controller?
In the 650 that would be 512???
Correct. With ssl fallback it will be half that.
Thank you very much clark!
