VIA running Slow
Hi All, I am running VIA client and Controller OS 6.1.0 and I have issues with users complain the client is very slow at connecting. It takes multiple tries.
Looked at the screen it first says
Remote Server Access - Not Reachable
Remote Server Access - OK
Connecting to Remote Server - Started
VPN Session - Initializing
Connecting to remote Server - Started
This process takes at least 20 sec's
But if we use the windows vpn client to connect to the same controller there is no issues connects in seconds.
Any idea's Luke
Re: VIA running Slow
Can you please send the via logs for debugging purpose?
Do you still see the problem?
