MVP
VIA, why bother with 64bit?
For users using non 64 bit browers on 64 bit computers the autodetection from VIA often offers the 32 bit VIA client.
Is there a real downside to using this 32 bit client for both 32 and 64 bit machines?
Koen (ACMX #351 | ACDX #547 | ACCP)
Re: VIA, why bother with 64bit?
The question should be: why not listing the available VIA clients on the controller? Or at least let the admin enable listing.
MVP
You can actualy list them all if you want.. takes a bit of scripting (see "Re-branding VIA and Downloading the Installer" in the manual) but then you get confused clients which may give you even more headaches :)
[ Edited ]
Thanks! :) Gonna try that...
--edit--
Just checked that part of the manual and it's the one I had already read. I can't get a listing of all available clients that I've made available.
MVP
Haven't actually tried this since I don't want users calling me with questions on which version to install but when you browse to Configuration > Advanced Services > VPN Services > VIA tab there's a section "Customize Welcome HTML".
You should be able to upload really any HTML file you want and that gets served to the clients connection to HTTPS://controller/via no? If you put a few simple a href links to your files you can display them that way.. I think.
