Contributor I
VLAN Pooling for Access Control
Can we leverage VLAN pooling to switch clients to multiple VLANs?
We have an Access Control User Role defined that switches clients to a different VLAN/subnet based on role. We have a need to expand that subnet but cannot expand it contiguously, so another subnet needs to be built. Can we leverage VLAN pooling to push clients to one subnet or the other dynamically? Only one VLAN ID may be specified in configuration.
Re: VLAN Pooling for Access Control
Yes you can.
http://www.arubanetworks.com/techdocs/ArubaOS_65x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/Network_Parameters/Configuring_VLANs.htm
Contributor I
Thank you.
Contributor I
