Contributor II
VLAN and GRE Tunnel
Does anyone here know if it is possible to encapsule différent VLAN in the same GRE Tunnel between 2 controller?
Thankx all.
Re: VLAN and GRE Tunnel
Yes
(192.168.1.3) (config) #interface tunnel 1
(192.168.1.3) (config-tunnel)#tunnel vlan ?
<WORD>                  VLAN IDs of the VLANs this tunnel should be part of.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
