Super Contributor II
VMC Scalability for IAP-VPN and Multizone
Hi Airheads,
Does anybody know where i can find sizing recommendation for using VMC as IAP-VPN termination or Multizone termination?
Scott
Re: VMC Scalability for IAP-VPN and Multizone
EDIT
Thank you
Victor Fabian
Lead Mobility Architect @WEI
supported in 8.3
Starting from ArubaOS 8.3.0.0, IAP-VPN is supported on Mobility Controller Virtual Appliance by using default
self-signed certificate (Aruba PKI). For Instant AP to establish IPsec connection with Mobility Controller Virtual
Appliance, the controller presents a default self-signed certificate which is uploaded on the Instant AP using
Activate.
Through Activate, you can push only one default self-signed certificate to Instant AP which can be used to establishIPsec tunnel with Mobility Controller Virtual Appliance.
