Contributor II
VPN problems
I have a few clients that need to connect to their corporate networks via various VPN client software and they're complaining that they can't connect and the connection times out. I've added the vpnlogon policy in the captive portal profile for the auth-guest user-role as shown below. Since the controller itself is not terminating any VPN sessions, is there anything else I need to do? Shouldn't this user-role allow for all vpn traffic to/from the controller?
user-role auth-guest
 session-acl cplogout
 session-acl logon-control
 session-acl auth-guest-access
 session-acl vpnlogon
 ipv6 session-acl v6-logon-control
 session-acl drop-and-log
Update:
Ok, I've looked into the problem a little more. After configuring the auth-guest role to remove all policies except the cplogout and logon-control and adding the allowall policy as well, I still have the same issue. The current authenticated user role looks like this:
 session-acl allowall
Doing a show datapath session table for the particular user trying to use his VPN client, I see that only traffic to/from UDP 500 to the VPN servers is being blocked:
  Source IP     Destination IP  Prot SPort DPort  Cntr Prio ToS Age Destination TAge Flags
x.x.x.x            y.y.y.y             17   500   500    0/0     0 96  0   tunnel 71   6    FDC
Does anyone have any ideas as to what could be causing this traffic to be blocked? I should add that the controller is not the default gateway for this traffic but a firewall instead. But would I see traffic being blocked by the firewall as being "denied" here at the controller as I'm seeing above?
Moderator
Re: VPN problems
The vpnlogon policy looks like this:
1 user any svc-ike permit Low 4
2 user any svc-esp permit Low 4
3 any any svc-l2tp permit Low 4
4 any any svc-pptp permit Low 4
5 any any svc-gre permit Low 4
Does the vpn client use something other than these protocols?
Kevin
Moderator
Re: VPN problems
I would suggest adding UDP 10000 to the vpnlogon policy since some VPN clients use that.  Add svc-natt (UDP/4500) as well, and make sure SSL (TCP/443) is allowed somewhere.
Austin
Contributor II
Re: VPN problems
The logon-control policy already allows for svc-natt. The auth-guest-access allows for https.
MVP
Re: VPN problems
I believe it's cjoseph that has a post listing this as recommended update for the vpn-policy:
Step #1 - The policy, apply from the command line of the controller,
under the config t mode
ip access-list session VPN-Clients
user any svc-l2tp permit
user any tcp 17 permit
user any udp 51 permit
user any udp 4500 permit
user any tcp 10000 10001 permit
user any udp 10000 10001 permit
user any svc-pptp permit
user any svc-gre permit
Step #2 -- Associate the new policy with the guest account as follows
(also from command line)
user-role guest
This might not completely solve your issue tho.
In a scenario where the Controller is the default gateway and doing NAT we've found that some VPN clients (especially microsoft vpn) doesn't work for our guest user. This is supposedly fixed in the recent 6.1.2.6 release, but we've not been able to test this yet.
Regards
John Solberg
-ACMX #316 :: ACCX #902 :: ACSA
Aruba Partner Ambassador
Intelecom/NetNordic - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
Contributor II
Re: VPN problems
Contributor II
Re: VPN problems
Wait a minute! Am I making all the changes to the wrong user-role? The captive portal authentication profile assigns a role of auth-guest to users that authenticate via the captive portal but their role shows up as guest after they authenticate, instead of auth-guest. I always thought that was a GUI thing. Do I need to apply these rules to the guest user-role, i.e. the VPN policies?
Re: VPN problems
When a user authenticates, type "show user" to see what role he gets AFTER he authenticates.
That is the role you are concerned about.
Contributor II
Re: VPN problems
The role after CP authentication is guest.
Re: VPN problems
So that is the role that you change.
