AJD
VRRP IP addressing for aruba controllers
all
question about VRRP on aruba controllers and ip addresses usage.  for example two 7205 controllers is it possible to create a VRRP instance on this pair and have the real ip also be the VIP?  so i would only require two ip addresses instead of three ?
thank you
Re: VRRP IP addressing for aruba controllers
You can create a VRRP between the two providing they are in the same L2 domain, the VRRP address must be a unique address.
This IP address must be different from the VLAN interface IP address on which the virtual router is configured.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
