  • 1.  VRRP problem
    Posted Jan 09, 2014 08:46 PM
    Hi all,
    one VRRP problem want to ask and i feel very confused.:smileyfrustrated:
    these two controller is Master/Local and Active/Passive Design. the controller uplink is trunk and user vlan gateway is on the swtich.
    i want to ask is that if the inter-link of the switch is broken, which controller will be become the active?
    any document can be provide??
    thx a lot.
  • 2.  RE: VRRP problem
    Posted Jan 09, 2014 10:37 PM
    In your drawing, if the link between switches is broken, then you will have a "split brain" scenario with BOTH controllers acting as VRRP master.  VRRP is a ROUTER redunandcy protocol...not a LINK redundancy protocol.  So...I would advise each controller with dual links to each switch but be careful about spanning tree.
  • 3.  RE: VRRP problem
    Posted Jan 11, 2014 12:02 AM
    so lacp is recommended design
