Contributor I
VRRP problem
hi everyone. I faced a problem in configuring Aruba equipment. So, I have 5 controllers in Master/local config mode (2 masters and 3 locals). They are using VRRP to provide redundancy and everything seems to be ok, exept of few APs. I found, that everything is working fine if APs are provisioned to use any of controllers as master. But they are going down while they are provisioned as VRRP VirtualIP as master controller IP address. Also, note that such behavior refers to a few APs, all other are in normal operatipnal state using VRRP VIP. All the controllers are in the same vlan, thay all are 3000 models and using ArubaOS 6.3.1.13
Community Administrator
Re: VRRP problem
Are the problem APs by chance an IAP converted to campus AP?
Also, have you manually set any of the env parameters?.
Airheads Community - The best place to Connect. Engage. and Learn.
Contributor I
Re: VRRP problem
No, there are regular APs. They are not converted from IAPs. Also, I tried to to change env settings. I found, that there is a problem with one VRRP instance at one controller. But I cann't understand the problem because others APs are working fine on current VRRP instance.
Re: VRRP problem
What is the difference e between those access points and the others? It could be anything like an incorrect t subnet mask....
Colin Joseph
Aruba Customer Engineering
Re: VRRP problem
Do you have the ability to compare a "bad" AP boot sequence to a "good" AP boot sequence?
Re: VRRP problem
We need to understand the working and non-working scenarios. What exactly few AP`s are doing when it doesnt come up. As Jamie mentioned, console logs cna give some inputs to understand behavior. Wondering, what happens when you reset one of the AP and point the master to VIP address ?
Thank you,
Sriram
Contributor I
Re: VRRP problem
Hi, everyone I'm sure that everything is ok with TCP/IP configuration of AP. I'll try to get boot sequence logs from APs and post it here later. Also, I found that bad APs are trying to make IPsec tunnels to VIP. I checked IPsec and ISAKMP SA and found that bad APs cannot build a tunnel. IPsec SA for that APs appears for a while and goes down.. So APs don't reboot because thay can reach the controller but cannot connect to it. If I'm using just an controllers IP address as master for bad APs everything is ok.
Contributor I
Re: VRRP problem
Output from APs boot are in attachments.
I found them equal. The only differense is that AP connected to XXX.XXX.XXX.30 master is ok, instaed AP connected to XXX.XXX.XXX.17.
APs are placed in the same branch and the same vlan, both refers the same AP group.
Re: VRRP problem
Can you get a printenv off of each one also?
These APs are not doing DHCP. So there has to be an error or dissimilar configuration.
Got all network params from APboot env. Skipping DHCP
XXX.XXX.XXX.XXX XXX.XXX.XXX.XXX XXX.XXX.XXX.XXX
Running ADP...Done. Master is XXX.XXX.XXX.30
Running ADP...Done. Master is XXX.XXX.XXX.17
Have you tried purgeenv on one of the bad APs?
Contributor I
Re: VRRP problem
jamie, I'll post printenv output later. I have to get it from APs, which are placed in branches. I was trying purgeenv and factory_reset commands but results was the same.
