Hi all,
I have two aruba controller and i want to use VRRP redundancy, but i have only one PEF-NG license. is it possible to use PEF-NG license with VRRP. what it will be if one of the controller down,
PEF-NG is an AP license, if you have just one then you can just have one AP active, is that the case?
as for redundancy you can use centralized licensing from version 6.3, that makes it possible to move the licenses with the active system.
