Via EAP-TLS with Machine cert
Hi All,
Is it possible to do this?
Via EAP-TLS authentication using the client Machine certificate.
Cheers
James
Cheers
James
Re: Via EAP-TLS with Machine cert
Yes.
Setup a Group policy that distributes machine certificates
Setup a Group policy that does only machine authentication.
Regular Contributor I
Isn't he asking about VIA?
The VIA client does not check the machine store when a user is logged in, although it checks the machine store before user login if you have "domain pre-connect" enabled.
ACMA ACMP
 I was talking about Via and I've configured it now so all good. :)
VIa checks the local certificate store on the machine. Client and machine certs are stored there and can both be used.
Cheers
James
