Frequent Contributor II
View default WMM to DSCP mappings
Is there a command to view the default mappings?
Re: View default WMM to DSCP mappings
http://community.arubanetworks.com/t5/Controller-Based-WLANs/What-are-the-default-DSCP-WMM-mapping-values-on-Aruba-WLAN/ta-p/175268
Colin Joseph
Aruba Customer Engineering
Since that article is several years old, I wanted to confirm that it is still valid and that values have not changed in later releases. Thanks for confirming.
You can confirm that by typing "show datapath session table <ip address of phone>" or you can set your own WMM to DSCP mapping in the SSID profile.
Colin Joseph
