Contributor I
Viewing Wired Authenticated Clients
Is there any plans to be able to view Wired clients connected via RAPs etc via the GUI?
Right now I have to filter clients by the Auth Type 802.1x and find them in the list.
They display as 802.1x-Wired as the auth type, would be handy to have a filter for this in the search feature or a seperate tab for them.
Just a suggestion
Unless this is already implemented and I havent found it?
Ian
