Virtual APs
Iam new to Aruba.. what is the difference between AP and Virtual AP and Vlan pool in APs
Aruba
Re: Virtual APs
I suggest you read up on each topic (links below), but in summary.
AP - the physical AP
Virtual AP - The profile thta encompasses the SSID and AAA profiles as well as other settings.  This is what is applied to the AP Group
VLAN Pools - Assigned to Virtual APs or User Roles, VLAN pools allow you to put clients on the same virtual AP onto different VLANs.
Virtual AP - http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Content/ArubaFrameStyles/VirtualAPs/VirtualAPs.htm
VLAN Pools - http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Content/ArubaFrameStyles/Network_Parameters/Configuring_VLANs.htm
AMFX | ACCX | ACDX | ACMX
