Contributor I
Virtual Mobility Controller 8.3.0.1 - problems with some mobile devices
Hi
I have a strange problem, It mainly appers on mobile devices like Android smartphones and tablets.
I have virtual controller on 8.3.0.1 version, and some 205,304 and 303 APs deployed as Campus without CPSec.
I haven configured typical WPA2-Personal, tunneled WLAN.
Notebooks works fine but mobile devices generally cannot get DHCP address and have concetivity problem.
When I set Ip adress manualy is the same
It is not rather related to radio environment, because network health seems quite high.
I have tried some debugging, but withou effect.
Please help
Karol
Re: Virtual Mobility Controller 8.3.0.1 - problems with some mobile devices
Can you share the user-role you are assigning ?
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor I
Hi Victor
I use default authenticated role
user-role authenticated
    access-list session global-sacl
    access-list session apprf-authenticated-sacl
    access-list session ra-guard
    access-list session allowall
    access-list session v6-allowall
Generally all my config now seems very typical, although it is possible that I have forgot about something
regards
Karol
When using a static IP, the client device still does not work?
Charlie Clemmer
Aruba Customer Engineering
Contributor I
Hi
Exactly, when set static IP address, it is the same, DHCP is simply the first service which the client uses, it seems that some packets arę somewhere dropped.
There must be a difference between windows and android/Linux
We arę after some houres od debugging with Aruba support, but at this moment without success, probably the problem will finally reach engineering team.
Do You have any idea ?
Karol
What are the particular android devices that are having problems? Since notebook computers work, I would ensure that the AP(s) are on valid channels supported by the android devices. Some older (non-802.11ac) android devices did not support DFS channels. If those are in use, that could explain the connectivity problems.
Charlie Clemmer
Contributor I
Hi
Sorry for a little bit late answer, I was a week on vacations.
I think that this is not the problem with radio and DFS channels, because in debug I can see that this devices associates correctly.
These devices which I use are: Samsung Note 4, Lenovo Tab A, Samsung Galaxy Tab.
Now, after some investigation it seems that when I set static IP on device it seems to work (although I had some problems before)
So it seems that there is a problem with DHCP, but only on some devices - mainly mobile.
There must be something wrong in VMware.
I have configured a network with Promiscius mode, MAC change and Forged enabled and tried to change NIC teaming load balancing algorithm but without effect. (Ip hash).
I have setup on a side one more ESX server witn Aruba VMC (on Intel NUC) and it works fine. The difference is I think that this is onlu ESX and only one NIC.
Any idea, what can I check more ?
Karol
