Occasional Contributor I
Virtual Mobility Controller - Control Plane Security
Is it true that the VMC doesn't support CPSec at all or just cert authentication for the lack of TPM?
Just installed a VMC with ArubaOS 8.1 and the CPSec tab is there and enabled.
Re: Virtual Mobility Controller - Control Plane Security
To be honest i had some issues getting CPEC correctly working. Eventually it seemed that after a (vMC) controller reboot a routing issue went away. Afterwards CPSEC works very good on the Aruba vMC.
So to answer, CPSEC does work correctly on a virtual mobility controller (vMC).
