Frequent Contributor I
Virtual Survey using VisualRF Plan
I am using visualRF to plan/tweak currently deployed wireless network. We have a two floor building and at the moment I am just planning for top level just to get an idea. Our APs are wall mounted and we won't be able to mount on ceiling due to building modification permission issues.
So my question is that I know when visualrf generates heat map it considers 99 percentile deployment scenario that is ceiling mounted APs and it shows me that I only need 6 APs considering 200 users and 20/radio. But for every AP which it has identified it shows same channel requirement that is for 2.4 it says channel 1 and for 5ghz it says channel 52 for each AP. Is this correct? Should I be not using three non-overlapping channels 1, 6 , and 11 in 2.4ghz band?
Also how I can relate the heat map to my deployment scenario that is wall mounted APs rather than on ceiling?
Thanks.
Farzan
Re: Virtual Survey using VisualRF Plan
VisualRF assumes that most if not all access points are mounted on the ceiling, instead of a wall, so you will not get accurate planning with VisualRF for your particular setup, because it expects a pattern matching how an access point is mounted on the ceiling.  Instead, Visual RF has an option to overlay a GRID over your drawing.  Just overlay a grid of 60 feet by 60 feet and make sure there is one access point in each box on the grid.  This will work for standard deployments for coverage.  It will NOT work for warehouses, or walls that are made of brick or rebar.  This will give you a starting point.
Would you please guide me from where I can set grid on my diagram?
One more question that why it advise to set same channel for all provisioned Aps on floor plan?
It does not spread out the channels.  the controller would do this automatically based on changing RF conditions, so it is not necessary to plot the channels.  If you had Airwave and put in your floor plans, it would tell you EXACTLY what your channels are at the time.  My advice (again) is to obtain an evaluation version of Airwave so that you can get critical and historical information about your environment  on the road to fixing your issue.
To show Grid lines on your diagram, click the Gears in the upper right corner:  Change Configure preferences to "Grid Lines"
Thanks.
As suggested by you I will aquire Airwave evaluation copy and will see how it goes. I will get back to this forum with more information for you to help.
Did they remove the preferences box in Airwave 8 using HTML 5? I can't seem to find it anywhere, and grids would be very helpful.
Thank you.
Moderator
To get grid heatmaps:
Navigate to a floor plan
Click to the 'View' options (on the right menu panel)
Under Overlays
Click the arrow next to Heatmap
Then check 'Show overlay as grid'
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
