Contributor I
Virtual controller limitations
We have a new location that has 3 floors that we will deploying IAP 105's with Airwave. So far we have determined that 17 AP's will be needed. I know that there is a limit of 15 AP's to a VC but can multiple VC's be installed to handle more than 15 AP's or is a controller needed?
TJG
Aruba
Re: Virtual controller limitations
There is no longer a cap of 16 APs per cluster.  Add that 17th one to the same VC and all will be good.
Aruba
To add, if you have IAP-92 or IAP-93s, the limit is still 16.
AMFX | ACCX | ACDX | ACMX
Contributor I
Thanks for the quick reply. Is there a cap on the number of AP's per cluster at all now?
TJG
Aruba
Thee is no hard cap outside of the IAP 92/93, but always use good networking common sense to limit the total number of clients on that layer 2 network segment.
