Frequent Contributor I
Visual RF Plan restore
I have installed the lates Visual RF Plan off the support site.  I did a backup and export of a pervious version on another pc.  I would like to import this backup file on the new pc, however, when clicking import, it jumps me out to a page that give me various scenarios on how to import this file.  When clicking on the link "Import Floor Plans From VisualRF Backup"  I get the following error:
Do not know how to handle /sites/visualrf/restore.htm
Is there a work around available to import this backup from another Visual RF Plan?  The version of Visual RF Plan is 7.7.rc1 (build: 440)
Thank you,
David Z
Occasional Contributor I
Re: Visual RF Plan restore
I get the same error. Also running 7.7.rc1 (build: 440).  I know it's not a supported product, but if anyone has an answer it would be greatly appreciated!
Hi Dzeising and Layer8expert,
I was  successfully able to import a floor plan to my Visual RF.
Here are the steps:
1/ Download the latest visual RF plan; It's build 448, as of write now.
http://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/EntryId/4830/Default.aspx
Then once installed, import the backup file (make sure its backup.zip).
Let me us know, if you have any issues.
Kartik
