Visual RF Plan wont import .dwg
[ Edited ]
Hello all,
im using the following version of VisualRF plan on win7x64
VisualRF Plan
Version
:Build Date:2012-03-29 07:36 PDT
Java Runtime Version: 1.6.0_22
 VisualRF Engine Version 7.4.0 (build: 315)
:VisualRF Engine Build: 7.4.0
VisualRF Engine Database: 63559
VisualRF Data Path: D:\IOC site plans
VisualRF Plan Static:63557
Now ive created campuses, and buildings, but when i try import a floor plan using cad drawings (.dwg) the software just shows a black screen where the drawing should be, and wont let me manually enter dimensions. If i click the b&w option, the "loading image" icon appears, the software then locks up and i have to use task manager to close it.
I have no issues with other filetypes, but my issue is i have hundreds of floorplans i need to create and all are cad. i dont have software to convert them (tried shareware and trial versions have limits)
so is there a solution to convert them for free (preferably batched) or is there an issue with my version of VRF ?
My apologies that my first post is a question. Just found this website and im running out of hair.. ;)
Regard's
paul
ps: ive attached a .dwg of the type im trying to work with
Moderator
Re: Visual RF Plan wont import .dwg
It looks like you have an older copy of VisualRF Plan:
VisualRF Plan
Version: 7.5.0 (build: 344)
Build Date: 2012-08-13 02:56 PDT
VisualRF Engine Version: 7.5.0
VisualRF Engine Build: 65853
VisualRF Engine Database: 54429
VisualRF Data Path: C:\Program Files\VisualRF Plan\data
VisualRF Plan Static: Unknown
All Rights Reserved. Copyright (c) 2002-2012, Aruba Networks, Inc.
Also, I didn't see an image attached to the post for me to try (it might have been stripped from the post).  Perhaps you can open a support case (support@arubanetworks.com), and they can escalate to me if needed.  Support will be able to confirm is there's an issue parsing the layers from the dwg file.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Hi Rob,
Im meeting Janet Stubbs and Raphael Zaks again tomorrow in Canberra to give me the latest copy of the software. Perhaps i can give them a disk with some example .dwg's and ask them to forward directly to you to check??  Hope to get on top of this asap..
regard's
paul
Moderator
That works.  Another option is to open a support case, support can provide you credentials to an FTP site where you can upload several plans.  That might be quicker and more direct.
Rob Gin
Thanks again Rob. Will do so tomorrow if i have no luck with the new version..
Hi Rob, Latest version fixed the problem. Thanks so much..
Moderator
Great, thanks for the update.
Rob Gin
