MVP
Visual RF orientation and Beamwidth
Hello Everyone
Im doing a simulation in visual RF with AP 175P
Now im wondering if im doing it properly
We are selecting omnidirectional antenas a Pair of 5 DB for 2.4ghz and a pair of 10DB for 5ghz.
In the propierties as its omnidirectional i should put in the orientation 0 and beamwidth 360?  i guess on the gain part i just put the values of the antenas im using....
Cheers
Carlos
Alternetworks Corp
MVP
Re: Visual RF orientation and Beamwidth
anyone?
Alternetworks Corp
Moderator
I'll have someone look into this and get back to you.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Aruba
The beamwidth should definitely be 360.  The orientation could be 0 or anything else.
MVP
Another question
if i use a antenna of 180 degreess then the beamwith should be 180
And what about the orientation ? i guess the orientation should be where to i want to point tha irradiation could be in front or in the back or something like that?
Alternetworks Corp
MVP
If you're using a 180degree patch, it generally has a direction in which it claims to send the beam.
Set the direction in VisualRF in the same direction you aim the patch.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
