MVP
VisualRF - AP neighbors appear for controller sites, not for iAP sites
We think we used to see AP neighbor relations shown in VisualRF (line indicating the signal strength with which each AP sees the neighboring APs) for our iAP sites.
Thinking that VisualRF had just gotten tired, I stopped and restarted.
Still seeing the signal-lines for controller based sites, and not for iAP.
Feature/Bug/Mis-understanding?
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Moderator
Re: VisualRF - AP neighbors appear for controller sites, not for iAP sites
I'm going to look into this.  I don't currently see anything in the background XML for AP to AP relationships, but will update when I find the answer.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Moderator
Update:
This is a feature request to file in the Ideas Portal: to see AP neighbors for Instant APs.  The functionality to include AP neighbor lines hasn't been built yet.
Rob Gin
MVP
I'll correct you RGin, the AP neighborship is back now.
Our iAP sites now happily show how loudly each iAP hears it's neighbor in VisualRF -- it appears only to show 2.4GHz, and not 5 so I may still need to open a feature request.
--Matthew
