Frequent Contributor I
VisualRF Plan 7.5
Is there a link so I can download VisualRF Plan 7.5?
Re: VisualRF Plan 7.5
Login to the support site and you can download it from there :
http://support.arubanetworks.com/DOWNLOADSOFTWARE/tabid/75/DMXModule/510/Default.aspx?EntryId=5079
Note: There's a new version 7.7 available too
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thanks. I have it bookmarked now :smileyhappy:.
