VisualRF Plan measurements
I am attempting to do a wireless estimate for a warehouse client who could not provide a floor plan. I measured the buildng and drew one up to scale. Once I imported the .jpg image into VisualRF Plan 8 I set boundries and used the measurement tool on the exterior walls.
The problem is that no matter how many times I measured to 70.10m X 17.64m the measurements in the properites do not come close. Is there something I am missing? Is there a way to manually set measurements? I would prefer that square meters on the building NOT be several hundred meters off.
Re: VisualRF Plan measurements
Forgive me. The dimensions of the building are 69.75m x 168.75m.
http://community.arubanetworks.com/t5/Network-Management/VisualRF-resize-problem/m-p/290410#M6371
Check this community link, which I posted couple of days back.
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
