VisualRF- Won't save IAP Beamwidth orientation and Gain settings. Upon Refresh settings default
I continuosly try to change AP properties in VisualRF. Once I change antenna Beamwidth, orientation, and gain. It will default back after first refresh. Can anyone help
MVP
Re: VisualRF- Won't save IAP Beamwidth orientation and Gain settings. Upon Refresh settings default
We had that problem in a prior version of Airwave and it was resolved in an update.
I don't immediately recall which version it was - I'll go dig through my e-mail history.
What version of Airwave ar you using?
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
MVP
I believe it was in 8.0 and fix in 8.1+ (my problem anyway)
--Matthew
Hi DNBWireless.
What  airwave release are you using?
Thank you.
Kartik
MVP
[ Edited ]
<edit>
Oops, posted to the wrong thread, sorry
</edit>
--Matthew
MVP
That was the wrong thread, sorry.
--Matthew
