Contributor I
VisualRF does not show (correct) heatmaps
In AMP 8.0.9.2 the VisualRF is not showing the heatmap on several floorplans.
On one floorplan with just 3 AP's we get a heatmap from only one AP (see image).
Wha tis goign wrong, and or how can we fix this?
Regular Contributor II
Re: VisualRF does not show (correct) heatmaps
I have seen this before, I would try:
  • Use different browser
  • Remove the AP from the floor plan and add it back on
    • after you add, poll the controller again.
Hopefully this helps :)
MVP
First, make sure you're not set to focus on the one AP - as that's supposed to just show one.
Second you can try this:
https://<airwave-name-or-address>/visualrf/poll_aps_now.xml
That forces all APs to be re-polled and data to recalculate, it takes a few minutes, but makes everything pretty again.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Occasional Contributor I
Same problem here. Removing AP and place it back doesn't work, restarting AMP services doesn't work, rebooting server doesn't work and force a SNMP poll doesn't work also.
We're on AMP 8.2.1 and controller version 6.4.3.9
An Aruba engineer already solved it in the past, but that doesn't solve the problem anymore.
Resolution:
  • Went on web session. Checked the APs status and found its showing error
  • Checked the xml file and saw radio skipping message
  • Disabled visualrf cleared the bootstrap cache and restarted it
  • Heat map started showing up correctly
  • There was another ap in a different floorplan not showing heat map
  • Found radio was showing good. It was issue with the floor plan
  • Resized it and it started showing correctly. Hence, closing the case
Any suggestions?
MVP
I recognize that path of steps - we followed it for quite some time.
It also stopped working effectively for us as well.
Have TAC look over my case #1922009 to see if they can see what was done to help me. I'm told that they've identified a bug which lead to our issues, and while we're still waiting for a final fix, Airwave and VisualRF have been much more stable/fast/and accurate since 8/17 when we made the last tweak.
--Matthew
Sounds good. Keep me posted please!
--Rolf
Any update yet?
-Rolf
Long time ago, but anyone have a solution yet? Still not resolved running on 8.2.3.1
Hi ,
Could you share latest heatmap screen shot? You mean heatmaps are incorrect or its not at all displaying?
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Sure, here you are!
I also don't know exactly why this is spamming our logs every minute. What does this do?
2017-05-15 13:18:36,192 WARN  Grid Bui[12] com.airwave.rf.SignalService ap placement concern incorrect_location for: 1324
2017-05-15 13:18:36,198 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 35
2017-05-15 13:18:36,199 WARN  Grid Bui[12] com.airwave.rf.SignalService ap placement concern incorrect_location for: 1333
2017-05-15 13:18:36,202 WARN  Grid Bui[12] com.airwave.rf.SignalService ap placement concern incorrect_location for: 1328
2017-05-15 13:18:36,202 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 81
2017-05-15 13:18:36,208 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 527
2017-05-15 13:18:36,210 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 925
2017-05-15 13:18:36,213 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 424
2017-05-15 13:18:36,217 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 325
2017-05-15 13:18:36,220 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 369
2017-05-15 13:18:36,222 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 447
2017-05-15 13:18:36,225 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 249
2017-05-15 13:18:36,228 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 525
2017-05-15 13:18:36,232 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 427
2017-05-15 13:18:36,235 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 405
2017-05-15 13:18:36,238 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 541
2017-05-15 13:18:36,242 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 442
2017-05-15 13:18:36,246 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 464
2017-05-15 13:18:36,249 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 145
2017-05-15 13:18:36,253 WARN  Grid Bui[6]  com.airwave.rf.SignalService ap placement concern incorrect_location for: 244
Mon May 15 14:34:23 2017	System	System	Restarting service Client Monitor Worker
Mon May 15 14:33:58 2017	System	System	Restarting service Client Monitor Worker
Mon May 15 14:33:44 2017	System	System	Restarting service Client Monitor Worker
Mon May 15 14:33:28 2017	System	System	Restarting service Client Monitor Worker
Mon May 15 13:52:28 2017	System	System	Restarting service Client Monitor Worker
Mon May 15 13:52:13 2017	System	System	Restarting service Client Monitor Worker
Mon May 15 13:51:28 2017	System	System	Restarting service Client Monitor Worker
