VisualRF in 8.0.0 missing map lock is there a way to get it back or how easy is a downgrade
VisualRF in 8.0.0 missing map lock is there a way to get it back or how easy is a downgrade?  I have moved 3 access points just trying to scroll around on the page and need to do a site visit to find them and put them back in place.
Trusted Contributor I
Re: VisualRF in 8.0.0 missing map lock is there a way to get it back or how easy is a downgrade
good question, anyone got some info on this?
The lock does not exist in the HTML5-based version of VisualRF.  You can change back to the Flash version by going to VisualRF> Setup.  Change "Enable HTML5-based UI:" to No to switch to flash...
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Moderator
This feature will be available in 8.0.2, we are working on adding it to the html5 version. It will always default to lock (irrespective of what the state was before) btw since we don't have the "undo" functionality.
Sujatha
