Visualrf not starting properly...
Hi, I have a problem with visualrf not starting or i should say not responding.  It is enabled and the system->status tab says the engine is "OK".  If you go to the Visualrf->floorplans tab it responds:
"VisualRF engine is not currently running. It may be disabled. Enable it on the Visual Setup page. The engine may take a few minutes to start after it is enabled."
At the end of /var/log/visualrf there is the following:
2012-03-27 13:44:40,031 WARN  Main         com.airwave.svg.init.Startup waiting for the AuthorizationService to bootstrap
any ideas as to what AuthorizationService i should be looking at?
thx
Re: Visualrf not starting properly...
I'm having problems with VisualRF starting too. I get the following error in the VisualRF log:
WARN  AirBusMs[2]  com.airwave.core.EventDispatcherImpl Thread[AirBusMs[2]] is waiting on service[Event] to start, method[fire]
After a little investigation it looks like VisualRF maxed out its allocated memory.
Contributor II
We have been getting this as well lately. We upgraded the memory on our servers. Check the sizing guide to ensure you are within your limits. I have also recently been told it may be fixed by upgrading to 7.4.8. I would check with TAC to see if this applies to your situation.
