Frequent Contributor I
Vlan Pooling Problem
I created multiple vlans into our controller together with the subinterface static ips appropriate with these vlans. I added these vlans using their vlan IDs into the vlan pool. I went and setup our SSID profile to use the vlan pool name that I created. However, this is not working. It will only work if I go back to only 1 vlan instead of using a vlan pool. Any ideas? I tried to connect to our network using the vlan pool in our SSID and it failed. I went ahead and set the vlan in the SSID as the vlan that I recently created and it failed as well. It is only working for the old VLAN that was setup. Do you guys think it is the external DHCP server?
Are those VLANs even on a trunk?  Is there a helper-address on the VLAN interface pointing to a DHCP server?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: Vlan Pooling Problem
Hope this helps:
Here is an example :
vlan-name test1 pool
vlan test1 10-15
vlan-name test2 pool
vlan test2 16-21
interface vlan 10
ip address 10.x.x.x 255..x.x.x
Make sure those VLANs are allowed on the trunks / port-channel back to the uplink switch
interface gigabitethernet 1/0
description "GE1/0"
trusted vlan 10-21
switchport mode trunk
switchport trunk allowed vlan 10-21
And then apply those to the VAP
wlan virtual-ap "office"
vlan test1
Thank you
Victor Fabian
Lead Mobility Architect @WEI
interface gigabitethernet  1/8
        description "GE1/8"
        trusted
        trusted vlan 10,20,53,200,999
        switchport trunk allowed vlan 10,20,53,200,999
You  missing trusted.... onthe port
Alternetworks Corp
Yep you right , thanks
Thank you
Victor Fabian
You were making the port untrusted :)
Glad its fixed
Remenber to mark  the asnwer as solution
Cheers
Carlos
Alternetworks Corp
