Vlan pools not saving
Has anyone had issues with vlan pools not saving in the gui on 6.1.3.4-AirGroup?
Re: Vlan pools not saving
Please make sure you clear your browser cache after upgrading...
I did after upgrading to get Airgroup to show in the navigation.    I just did again to see if another clear would fix the vlan pools now showing and it did not.
Old ones I created back when we first got the controller show.  But the two I attempted to create today do not show in the GUI.
show vlan mapping  also doesn't return the newly created vlans.
Brandon
Please open a case so we can investigate and get fixed....
