Regular Contributor II
Vocera Guide
We will be doing a demo of the Vocera badges. Is there a Vocera guide? Is there anything that can be tricky with the configuration?
Re: Vocera Guide
Aruba controller has a ALG for vocera so it should able to detect it from a firewall perspective , make sure that on the SSID you have the lower data rates enabled
There's already a Vocera ACL available on the controllers:
Make sure you read this document  which has some good tips to allow Voice devices to roaming appropriately on wireless:
http://www.arubanetworks.com/wp-content/uploads/DG_Roaming.pdf
http://www.arubanetworks.com/techdocs/ArubaOS_61/ArubaOS_61_UG/Voice_Video.php
And also Vocera has best practices to work properly on wireless :
http://www.vocera.com/products/documents/InfrastructureGuide.pdf
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Re: Vocera Guide
Check out this link for a full guide: http://www.vocera.com/products/documents/InfrastructureGuide.pdf
Check out this link for a summary guide: http://www.vocera.com/assets/pdf/documents/Vocera_IPGP_Summary.pdf
They should point you in the right direction.
Also, in this post: http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Vocera-ACL/td-p/48080 cjoseph mentions that Aruba's Roaming Devices VRD has a template for Vocera.
I just went through tweaking my Vocera network about a year ago.
Re: Vocera Guide
I have found a Design and Implementation Guide on the Aruba sight but it seems a little dated.
