Volume based Internet Connection
Hi Guys,
We have external Captive Portal connected with Radius(AAA) and Aruba 650 Access Controller. What we have now is only Bandwidth Contract per Role.
Do you have idea how to set the Volume based per client. For Example:
1) Role A - 5MB consumable per day
2) Role B - 30MB consumable per day
3) Role C - 100MB consumable per week
Or if this is not possible can you give us the alternative way.
I hope you can help us.
Thank You,
Bien
Re: Volume based Internet Connection
You need a policy-based radius server like ClearPass that can (1) Measure client traffic using Radius accounting and (2) Make a decision per day, based on that information.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hi Colin
I never experience the  ClearPass. Can you give us a live of document or patner how the clearpass working with the volume based.
Bien
MVP
http://www.arubanetworks.com/products/security/network-access-control/ should have all you need.
Koen (ACMX #351 | ACDX #547 | ACCP)
MVP
http://www.arubanetworks.com/products/security/network-access-control should have all you need.
MVP
 http://www.arubanetworks.com/products/security/network-access-control/ should give you all the info you need about clearpass and where to get it.
