WALLED GARDEN WHITE LIST ISSUE
hi,
I can not delete mac address on walled garden white list.Therefore the computers which have this mac addresses in the white list, can not connect the network.
I di not solve this problem.Thera are 3 mac-address on list.When I clear the list which it self creating same mac-address again
what this the reason this ?
regards,
Re: WALLED GARDEN WHITE LIST ISSUE
Walled Garden entries should be domains, not mac addresses.  http://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#UG_files/CaptivePortal/Walled_Garden_Access.htm?Highlight=whitelist
What are you trying to do?
the mac-address in the white-list is created itself. I didn't create mac-address. Devices with mac-address at the list can not connecting to the wi-fi. I deleted mac-address but mac-address self-adding to the list as automatically
What is the configuration for your SSID?
what exactly do you asking. If you want you can connect to my computer to check the ssid configuration
regards
ok I solved the problem.I cleared the white list.
thank you .
