Occasional Contributor I
WEB Access controller 7210
wanting to check the web access to see if its allowed in controller by CLI just wondering what command I would use to check this.
Also the web access would use  ports 443 and 4343 correct
Re: WEB Access controller 7210
By default web management access is allowed.  You would have to know where to turn it off or switch it to another port.
