WHAT SHOULD BE THE MANUAL SETTINGS ON LAPTOP WHEN ITS NOT CONNECTING TO A 80.1X RADIUS SSID.
WHAT SHOULD BE THE MANUAL SETTINGS ON LAPTOP WHEN ITS NOT CONNECTING TO A 80.1X RADIUS SSID .WHEN POLICY PUSHING WAS NOT DONE BY AD SERVER.
Mallikarjun
Re: WHAT SHOULD BE THE MANUAL SETTINGS ON LAPTOP WHEN ITS NOT CONNECTING TO A 80.1X RADIUS SSID.
What type of network is it?
Tim Cappalli | Aruba Security
EMPLOYEE NETWORK.
Your title says "not connecting to an 802.1X SSID". So what authentication
method is in use on the SSID you're trying to connect to?
802.1x authentication
Did this ever work?  The manual settings depend on what the administrator has configured on the radius server side.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
