Contributor I
WHat will be the difference when using AP215 or AP205 with RTLS Management?
Hi
I am trying to work out which AP to use for RTLS. Whether to use AP215 or AP205 and what difference does it make?
From the research i have done, i dont see much difference as RTLS requests information from the controller not APs. Am I correct?
Also second question is where can i find whats the purpose of SDRAM and FLASH in the APs?
Mahathma
