Frequent Contributor II
WHy AP fast failover work but cleints Can't connect and give Error Authentication faild?
I have 2 Controlers Master and Local Access Points are terminated on local and I used the Maser a Standby for the APs, Now When I disconnect the Local APs fail over to the Master but after that the Cleints can not connect and give error authentcaition faild and when I connect back the locacl the APs returen to local but still clients can not connect aslo but with no msg just client keep trying to connect and then nothing happen the only way to make client able to connect is to reprovision all APs and then it can wor on local again Ai'm Using OS 6.4
Re: WHy AP fast failover work but cleints Can't connect and give Error Authentication faild?
Is your master configured in your radius server as a radius client?
Tim Cappalli | Aruba Security
I'm using Normal PSK, no external RADIUS
Did you enabled client State sync ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Does your master controller have the same client VLANs as the local?
@victor :how to enable it?
@Cappali : yes
I really thank you for your support
http://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Content/ArubaFrameStyles/VRRP/HighAvStateSynch.htm
Thank you
Victor Fabian
Dear Victor,
I Already enabled it and also enabled preemption, Should I enbale Heartbeats ?
