WIP Demo License for 3600 controller
Guys,
Do somebody know why when Im in the license portal and I try to look for the WIP 16 license for a 3600 the option is not available.
I tried using 800-16 license and also SC-I for 48 but none of those worked, I got a message stating that are not supported for that model.
Please help.
Thank you.
Contributor I
Re: WIP Demo License for 3600 controller
Use the "EVL-RFP-1024". They will work fine
regards,
Paulo Raponi
Thank you!
