Regular Contributor I
WIPS Issue after update to AOS 6.4.4.8 3200 controller
HI All,
i have updated a 3200 controller to AOS 6.4.4.8
After this update, the wizard of WIPS crash and not allows me to make changes.
Is not possible for me choose anything, because the page is not loaded.
In the release note there is not anything into "KNOWN ISSUES".
Have you any idea?
I know that i can do same change via CLI but i want to solve the issue.
I already tried to use different web browser and different version.
Regards
Andrea
Andrea
Re: WIPS Issue after update to AOS 6.4.4.8 3200 controller
Should be fixed in AOS 6.4.4.9, it was discovered after the release notes and code were published. I believe the target for 6.4.4.9 is late July/Early Aug.
Jerrod Howard
Sr. Techical Marketing Engineer
i'll wait the next versione of AOS.
Regards
Andrea Acampa
Andrea
