Contributor II
WLAN CONNECTION IRREGULARITIES
I am currently having some connection problems in my WLAN, i therefore debugged client and got the results below, can someone explain what the messages mean, and what the problem is:
version 5.0.3.0-1.1.0
virtual-controller-country DE
virtual-controller-key cff5adbf014426cfb9547bc010dfaad80ea4ee1ce5595390f1
name Instant-C9:B1:B7
terminal-access
rf-band all
allow-new-aps
allowed-ap d8:c7:c8:c9:b1:b7
allowed-ap d8:c7:c8:c9:b1:c7
allowed-ap d8:c7:c8:c9:38:4f
allowed-ap d8:c7:c8:c9:b1:a1
allowed-ap d8:c7:c8:c9:b1:35
mgmt-user admin e459252c207483972e0aa9b077beb5decc6bc17a857df186
wlan ssid-profile WLAN1
index 0
type employee
essid WLAN1
wpa-passphrase b34cd25c5af6d9e461fce99f25671394b117494b299f1b5f
opmode wpa2-psk-aes
vlan guest
rf-band all
captive-portal disable
wlan ssid-profile WLAN2
index 1
type employee
essid WLAN2
wpa-passphrase 270b4a7bdeac1347efa7a5f9a0292ca41ec431be0b87c469
opmode wpa2-psk-aes
rf-band all
enet-vlan guest
wlan access-rule WLAN1
index 0
rule any any match any any any permit
wlan access-rule WLAN2
index 1
wlan external-captive-portal
server localhost
port 80
url "/"
auth-text "Authenticated"
Valued Contributor II
Re: WLAN CONNECTION IRREGULARITIES
This out put is not enough to identify the issue, can you please explain what type of issues you are facing ?
1. Connectivity ?
2. Authentication ?
3. VLAN and IP address ?
I found some thing in your out put,
1. Why are you broadcasting both the SSIDs for employees with the same Authentication (wpa2-psk-aes)
2. Why WLAN 1 is mapped to Guest VLAN ?
3. I guess you are trying to broadcast 2 SSIDs  one for Guest and other for Employee right. if so please correc your configuration accordingly.
index 0
type employee
essid WLAN1
opmode wpa2-psk-aes
vlan guest
rf-band all
index 1
type employee
essid WLAN2
opmode wpa2-psk-aes
rf-band all
enet-vlan guest
Cheers,
Venu Puduchery,
You are running very old code. Are you able to upgrade?
Tim
Tim Cappalli | Aruba Security
Contributor II
I tried to update the firmware through the web interface. But it says i have the latest updates.
Is there some other way to upgrade?
Sent from Samsung Mobile
Contributor II
Thanks very much for your assistance and reply. I found a solution to the current problem. I just factory reset the APs and setup everything from scratch.
