Occasional Contributor I
WLAN mode (amber) vs N Mode (green)
Hello - we have several APs at a remote location that have both 11A/N and 11B/G/N LEDs showing Amber.
Aside from this in the install guide I see no references as to what the differnence is; what they should be. I assume Green.
Can anyone link me to what the difference is between WLAN mode and N Mode?
Is there anyway to force N Mode / Green lights?
Thanks.
Retired Employee
Re: WLAN mode (amber) vs N Mode (green)
You need to enable "high-throughput" under "rf dot11a/g" radio profiles to make them green
HT
When I check ".bg HT Mode" it shows:
HT-20mhz
But the lights are still red? Any thoughts?
Aruba
[ Edited ]
Please check your settings on the following screen
Configuration/all-profiles/wireless lan/virtual-AP/SSID-profile/high throughput SSID profile
"Highthroughput Enable (SSID) == checked"
The setting you indicate above would only affect one of the radios in the AP, not both... so even if that was the setting it would not change both LEDs ;)
Please try verifiying the settings I have here and see if the highlighted setting is 'enabled' at this time.
Tks!
JF
