Contributor I
WLC Controller Admin Access need to Block from Guest Network
hi am trying to block 7010 WLC admin portal access (port: 4343) from Guest network but its not happening.
we created a policy (block-internal-access) (source: user, Destination: controller IP, Service: tcp 4343, action: deny) and added to Post Logon Role (Auth-Guest Role) and mapped Auth-Guest Role to Captive Portal.
captive portla add on initial Role (Guest-Logon), Guest-Logon role add on AAA (dot1x-PSK) and finally mapped to Virtual AP.
but guest users still able to access WLC admin portal login page.
Ref attachement.
1. Block-Internal-Access
2. Auth-Guest Role
Re: WLC Controller Admin Access need to Block from Guest Network
Are you sure that is the role that your users are in?
Colin Joseph
Aruba Customer Engineering
Contributor I
yes, it could be.
we have created a local user (as a guest) and role is assigned to Guest SSID. how can we confirm this.
also could you please help me to clarify on thing Firewall /Auth-Guest Role is assigned to Guest SSID(ex: AWNICA-GUEST), so once we assign any firewall /access-list to this SSID /AAA policy all connected user (user who is connected to this SSID) have the configured restriction, am i correct.
You have to type "show user" on the commandline or look at the user table on the monitoring page to find out what the current role of the user is.
Colin Joseph
