WLC dashboard total clients vs Monitoring clients values
Dear Aruba Engineers,
Wenn I have a look on my WLC's dashboard, the amount of clients displayed (Dashboard > Performance > Performance Summary > Total Clients) is not the same as the value displayed in the Monitoring > Clients page. This last value is almost 25% higher as the first.
Do you know what's the difference?
Kind Regards,
Nicolas.
Re: WLC dashboard total clients vs Monitoring clients values
You should open a TAC case so that they can look at your logs.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
