Frequent Contributor I
WMM without PEF
Hello, for my understanding it is necessary to have the PEF Licence installed to configure CAC and the EDCA Parameter for Voice Clients. So without the PEF Licence i can activate WMM in the SSID function. What part of WMM is activated without the PEF Licence? What is the difference between WMM with PEF and without?
Thank you and best Regards
Re: WMM without PEF
With WMM allows you to use the more efficient power save option that's a very important for VoIP clients and also allows to identify / flag the traffic (wireless classification ). , this happens with or without the firewall
With PEF you prioritize the way that traffic is process under the user-role by the firewall
Thank you
Victor Fabian
Lead Mobility Architect @WEI
