WMS General Learn-System-Wired-Macs Enable Command
Hey All,
Have a possible newb question here - the command "wms general learn-system-wired-macs enable" command is not an option for me.  These are the only options available under the wms command:
(config) #wms ?
ap                      configure AP mode
clean-db                Clean Database
client                  configure client mode
export-class            Export classification data to a file
export-db               Export DB to a file
import-db               Import DB from a file
reinit-db               Reinitialize Database
We have the RFProtect License (with WIP + Spectrum Monitoring) and we're currently running OS version 6.1.3.5.  Any reason why that command isn't available?
Brian
Re: WMS General Learn-System-Wired-Macs Enable Command
Please type "show keys" to make sure your licenses were applied.
(FLMWLANCONT001) #show keys
Licensed Features
Feature                                             Status
Access Points                                       32
Remote Access Points                                32
Ortronics Access Points                             0
Outdoor Mesh Access Points                          128
RF Protect                                          32
Voice Service Module                                Unlimited
VPN Server Module                                   2048
xSec Module                                         0
Indoor Mesh Access Points                           128
120abg Upgrade                                      0
121abg Upgrade                                      0
124abg Upgrade                                      0
125abg Upgrade                                      0
Next Generation Policy Enforcement Firewall Module  32
Advanced Cryptography                               0
Service provider AP                                 0
RF Protect                                          ENABLED
Policy Enforcement Firewall                         ENABLED
Remote APs                                          ENABLED
External Services Interface                         ENABLED
Client Integrity Module                             ENABLED
VPN Server                                          ENABLED
xSec Module                                         DISABLED
MMC AP                                              DISABLED
Netgear AP                                          DISABLED
Voice Services Module                               ENABLED
Ortronics AP                                        DISABLED
Mesh Point APs                                      ENABLED
AP Developers Module                                DISABLED
Internal Test Functions                             DISABLED
Public Access                                       DISABLED
Policy Enforcement Firewall for VPN users           DISABLED
Content Security                                    DISABLED
Advanced Cryptography                               DISABLED
L2/L3 Switching                                     DISABLED
In order to enable this command, you must go into the wms general profile like so:
(MLIXWC1TOR200) (config) #ids wms-general-profile
(MLIXWC1TOR200) (IDS WMS General Profile) #learn-system-wired-macs
This should do it for you.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Pmonardo,
Thank you!
For once I can answer a question!!!!
ACDX #420 | ACCA
Thanks - that worked!
Could you please let me know if enabling this command will allow the controller to classify a Rogue device without the need to trunk client VLAN to the APs/AMs?
It will collect all of the wired mac addresses from the controller VLANs, yes.  Those mac addresses are propagated to access points so that they can correlate them to things seen on the wireless network.
