Is this the same product here: http://www.healthcare.philips.com/us_en/products/patient_monitoring/products/telemetry/ ? If not, in what range does it operate? If it is not in the 5ghz band, it *should* not interfere.What VOIP phones does the customer have?
I do not know about the third harmonic. If you have a spectrum analyzer, you could certainly put the issue to rest. With regards to the phones specifically, however, you can look at the Aruba Guide to Roaming devices to get parameters to optimize your phones so that they work their best here: http://www.arubanetworks.com/pdf/technology/DG_Roaming.pdfIt could be something besides the Telemetry system.
