Contributor I
WPA-Enterprise/TKIP and WPA2-Enterprise/AES - single ssid
I have two question regarding controller configuration:
1st: I would like to configure simultaneously both WPA/TKIP and WPA2/AES security option on the same ssid. Is it possible? If yes, how can I do that?
2nd I would like to create a group of APs which will broadcast the same ssid. I would like that my device will consider this group od APs as single BSSID device. Is it possible?
Mateusz
Re: WPA-Enterprise/TKIP and WPA2-Enterprise/AES - single ssid
1) use mixed mode under the SSID encryption settings.
2) No, this is not possible
Tim
Tim Cappalli | Aruba Security
